Old 12-12-2001, 06:35 PM
RCReed RCReed is offline
I need to know the part numbers for the correct intake manifolds that will work with a Quadrajet setup with Mechanical choke. I have a 1967 LeMans with a 326 ci.
Thanks guys and gals
Old 12-12-2001, 10:01 PM
Blackcat's Avatar
Blackcat Blackcat is offline
Bonker's-T-Cat Moderator
Don't have the part numbers handy but the 67 Q-jet intake is easily identified by the heat grove in the base where the carb mounts.
Any 4bbl Intake from 67 to 71 will work with no problems. The Carter AFB intake from 65-early 67 will also work on the engine.
So, Blacky, what's your biggest turn on? Is it that Big Blue Ball that the Tiger is holding? Rash
Try calling CRUSHPROOF! 512-386-9889
Old 12-13-2001, 10:30 PM
I have a Quadrajet 4BBL #2823 #7044244-KD
I have intake manifold #525355 or 525855 C187 that fits? Not my 67 326 w/this Carb.
I can choose 68 #9790140 C128 or #9786286 C107
What do you think (except: that I don't know what I am doing)?
Old 12-13-2001, 11:19 PM
Blackcat's Avatar
You can use the later Q-jet intakes. If your engine is a true 67 326.
The Q-jet carb will bolt right up. However you will need a new Cable braket and cable for the Q-jet. PY chould carry them.
The other intake is a early Pontiac For an AFB carb. If it doesn't fit that makes it an early one.
Old 01-09-2002, 12:35 AM
I have the parts I need... Thank to all of you.
