Old 03-26-2005, 01:37 PM
68LeMans_ger's Avatar
68LeMans_ger 68LeMans_ger is offline
1. There are three holes in my 68 LeMans above the rear window (picture: http://euw.dyndns.org/pics/missing_part.jpg), but only one coat hook. What else is supposed to be there?
2. I found two emblems in my car and don't know where to put them. Can anybody tell me, where these emblems (http://euw.dyndns.org/pics/emblem.jpg) normally are arranged?
Thanks a lot,
Daniel
68 Pontiac LeMans
Thanks a lot,
Daniel
68 Pontiac LeMans
Old 03-26-2005, 01:44 PM
Brew Brew is offline
I think the holes in the headliner are for the shoulder belt retainer, which I believe was optional.
67 LeMans vert w/462
68 GTO bone stock
Old 03-26-2005, 02:37 PM
goatless's Avatar
goatless goatless is offline
Those emblems appear to be for the door panels. They are located in the upper center area of the panel.
1966 GTO
Old 03-26-2005, 03:01 PM
Thanks for the quick answers.
Brew: Actually my LeMans does not have belts at all (front+rear), but perhaps they have removed them.
goatless: There are other emblems on the door panels (http://euw.dyndns.org/pics/door_emblem.jpg) - aren't those the original ones?
Daniel
68 Pontiac LeMans
Old 03-26-2005, 03:14 PM
goatless's Avatar
The ones in your first post look like the ones on my '69. The others that are mounted on your car may be the correct ones for a '68.
1966 GTO
Old 03-27-2005, 04:24 PM
1-GTO's Avatar
1-GTO 1-GTO is offline
Send a message via Yahoo to 1-GTO
I agree with Brew....those are the mounting holes for the shoulder harness belts.
GTO.....Gran Turismo Omologato,True Pontiac Excitement!
Old 03-30-2005, 05:52 AM
Kenth sweden Kenth sweden is offline
hi there in Germany
the emblems that you showed is not for the 68 lemans. look behind and if you find part# you can check it out in the partnumber system on first page. Are you comming to Poweer meet in Vasteras this summer with your car?
"Nisse"
Old 03-30-2005, 07:49 AM
There are no items with the number on the back... But a younger models door emblems sounds probable to me.
Where is Vasteras? Sweden?
68 Pontiac LeMans
Old 03-31-2005, 12:03 AM
hi
If you have a map you can find stockholm. look a little bit to the left in map you will find Vasteras. look here about power meet http://www.bigmeet.com/
"nisse"
