Old 11-03-2002, 04:52 AM
paul 67gto paul 67gto is offline
Been checking thr arcives regarding the crower 60916 & 60242. Very simmilar specs!
What would the diference be in a hicomp 400 in general? I know a couple of guys hve run this cam in a 400,any advice?
Paul
Paul
Old 11-03-2002, 07:14 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Have made great numbers with the 60916 cam on the dyno and at the track. It is a very good cam for 400 street engines with the early high compression heads. Have always used HS 1.65 rockers on it. Haven't tried the other cam mentioned as KRE stocks the 60916 and the specs are just about identical.....Cliff
