Old 06-06-2000, 08:34 PM
bigunde bigunde is offline
I just run across a 455 that is code WX.
It came out of a 76 Trans Am.Is it a
4 bolt main???Thanks
Old 06-06-2000, 08:36 PM
Blackcat's Avatar
Blackcat Blackcat is offline
Bonker's-T-Cat Moderator
If it has a 76 casting date. No it is not.
Most 4-bolt 455's were built between 1970 to
1974 end with the 455SD's
Try calling CRUSHPROOF! 512-386-9889
Old 06-06-2000, 08:43 PM
The block has a 75 cast by the distributor
hole.I have got to clean it and get the
casting dates a look see.Thanks
Old 06-06-2000, 09:05 PM
Judge Smails's Avatar
Judge Smails Judge Smails is offline
Bad news:
Not only doesn't it have 4-bolt caps, but the '75-'76 455 blocks weren't even factory drilled for 4-bolts.
Sorta good news:
If it's for the street, you can get by with 2-bolt studs ok.
[This message has been edited by Judge Smails (edited 06-06-2000).]
Old 06-07-2000, 03:14 AM
Engo's Avatar
Engo Engo is offline
Sorta good news 2:
If it´s for racing, you can have it drilled for splayed 4-bolt main caps.
Street/strip 1969 TA clone. Back halfed. 3300lbs. Twin turbo LSX 387cu. JW glide. Holley Dominator EFI. E85. Street driven.
https://www.facebook.com/photo.php?f...type=1&theater
Old 06-07-2000, 11:20 PM
Gach's Avatar
Gach Gach is offline
Now here's the bad news, those blocks ten to have very thin walls, so if it needs to go .060 over have it sonic test first. Actually being that it's a 455 block I would have it sonic test anyway, I have a friend who didn't, and he just went .030, the block crack on his thrid pass with only 1200 mile on his new motor.
