Old 07-13-2005, 02:42 PM
67HOVERT 67HOVERT is offline
Just checking to see what code or stamp I need to have a picture of to show it #'s matching while it is out and painted nice. Also, how do you break it down? Thanks again!
Old 07-14-2005, 05:45 AM
racerboy's Avatar
racerboy racerboy is offline
Stick or automatic?
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
Old 07-14-2005, 04:59 PM
4 speed. I forgot that
Old 07-15-2005, 09:52 PM
baron_ baron_ is offline
Send a message via AIM to baron_
shouldn't it have a partial VIN # stamped on it?
so look up your vin and then look around the tranny for any variation of it
and as for breaking it down, in one of the codes there's a letter designation
A B or C if i remember right
I think A was M20, b=m21, c =22, if i remember correctly (or something like that)
someone correct me if i'm wrong
Clay Marsh
1967 GTO convertible Twin Turbo 5spd project
http://forums.performanceyears.com/f...d.php?t=618281
http://www.youtube.com/watch?v=eJ9KworCMRE
Old 07-16-2005, 06:46 AM
I dont think the had a VIN on them until late 67 or starting in a 68 model. I could also be wrong though.
Old 07-17-2005, 10:38 PM
67Goatboy 67Goatboy is offline
Yea VINS weren't stamped until 68 and the only way I've been told to check trannys is just to run the dates codes on it, year one has a tranny decoder I think on their website.
Good enough for the girls I go with!
Old 07-18-2005, 06:20 AM
Bob Kazian Bob Kazian is offline
I have a '67 GTO (Baltimore Plant) and a '67 LeMans (Kansas Plant), both 4-Speeds with 10D build dates and both have the correct VIN numbers stamped on the top of the front case of the transmission.
Bob Kazian
Taylors, SC
[email protected]
Old 07-18-2005, 06:28 AM
slowgto slowgto is offline
The following link is what I use to ID my trans.
http://www.5speeds.com/muncie2.htm
I believe some years had a two letter code painted on them too, but I have never seen one.
