Old 04-06-2005, 02:01 PM
pontiac4 pontiac4 is offline
WHAT IS THE WS6 PACKAGE AND WHAT ALL DID IT INCLUDE.
Old 04-06-2005, 04:38 PM
Messman71 Messman71 is offline
In what year? I had a 2002 WS6 Trans Am. All it was was a funtional Ram Air Hood, special 17" Polished Wheels and Tires, and a special exhaust (single with dual outlets). Not much, thats for sure.
Old 04-06-2005, 08:01 PM
On the older TA'S it consisted of larger front and rear sway bars, a quick ratio sterring box I believe, and maby a different rear end ratio and 15X8 snow flakes.
It may have had more than that but it was mainly suspension stuff.
Mike
Old 04-06-2005, 08:17 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Louisiana got it right for the early ones , also had a set of nylon front sway bar end links, and s slightly stiffer rear spring eye bushing and spring.Alos came with the Polysteel tires and shocks for the package.
Skip Fix
Old 04-07-2005, 01:58 PM
disc0monkey's Avatar
disc0monkey disc0monkey is offline
DISC BRAKES! on the the 78-81. other than that it mostly tightens up the suspension
Old 04-07-2005, 02:10 PM
Skip Fix's Avatar
Rear discs were available in 79 for the first time.
Skip Fix
Old 04-08-2005, 08:15 AM
matt hatten matt hatten is offline
The 78/79 TA had the 220hp 400. Both had the 15x8 snowflake wheels. Plus what was said in the above posts.
