Old 04-30-2001, 12:56 PM
Poncho64 Poncho64 is offline
Anybody have problems getting the starter off a 389 in a 64 lemans, I know it seems strange but I can get the bolts out and it unhooked but I cant move it away from the bellhousing enough without it hitting the frame and I cant move it forward enough to drop down without it hitting the bellhousing? Do I have to jack up the engine and take it off the motor mounts or what?
Weird problem isnt it
Old 04-30-2001, 05:54 PM
Old Man Taylor's Avatar
I don't recall for sure, but I think you have to disconnect the exhaust. The starter goes out nose up. There is a notch in the frame to allow it to go above the frame. Again, at least that is what I remember.
Jim
Old 05-01-2001, 08:06 AM
Guy Mazza's Avatar
Guy Mazza Guy Mazza is offline
Yes, that is weird, I have 3 64's & just replaced the starter in my daily driver '64 LeMans w/'72 350. Mine comes right out, no interference whatsoever. Like OMT said, is the exhaust in the way??, you might have to drop the headpipe. Good Luck. Guy
Old 05-19-2001, 12:40 PM
The exhaust doesnt seem to be in the way its just that that the crossmember and the bellhousing interfere, I mean I only lack a 1/16 of an inch. Anybody ever experience this problem, I have a hot start problem so bad that I have to park on a hill everywhere I go because the guy that had it before me put a 2bbl 326 starter on it. I am about to the point of buying a mini starter and busting the nose off the old one with a hammer to get it out. Any suggestions?
Old 05-20-2001, 09:02 AM
66Bronz 66Bronz is offline
Dude, you really have to disconnect the headpipe from the exhaust manifold there. My motor is a 66 389 & it's definitely a tight squeeze but it drops thru. I put on a heat-shield to help with hot-start problems, which are caused by being so close to the exhaust! If you do that, put the starter in 1st & wire it up- then put on the heat shield, then reconnect the manifold & pipe.
