Old 03-15-2001, 05:51 PM
T-Man T-Man is offline
On my 67 Lemans I have a 455 out of a 72 Grand Ville that the previous owner put in. The motor is stock w/ 60,000 miles on it . The other night I was turning it 4,000 rpm's and then the oil pressure at idle went from 35 or so to 10 or so. Any Ideas?
Old 03-16-2001, 11:31 PM
Ed Neasham Ed Neasham is offline
First get another pressure gage and check it against the one you have. You'd really hate to pull your engine and find out the gage went bad (and they can do that).
If it really shows 10 psi at 4000 rpm and the oil level is normal then you've either got a pump that went bad or you have developed some serious clearance openings in the engine. In either case you had better tear into it. YTou don't want to drive it under those conditions.
