Old 04-06-2005, 09:47 AM
"Teacher
Send a message via MSN to
What is the cut off year to direct bolt a 70s 400 into a 69 Pontiac, with a 69 400 turbo? I also know the motor mount bolts changed, but when? Thanks.
I can do all things through Christ, which strengthens me..
"Teacher
Old 04-06-2005, 09:53 AM
engineer engineer is offline
all 69-80 use the three bolt mount. Earlier used 2 bolt mount.
Old 04-06-2005, 10:52 AM
Frank R's Avatar
Frank R Frank R is offline
In 1970 the blocks went to five holes for the motor mounts. A-Bodies up to 72 use the same two holes that they always did. F-Bodies use the three new holes for motor mounts. Some of the late 70's blocks are not tapped in the two holes you need. So if the block has threads in the two holes you should be ok.
Old 04-06-2005, 11:11 AM
"Teacher
The first answer was simpler. Now, there is a 400 out of a 78 Bonney. Will this work? Do I need to count holes?
Old 04-06-2005, 11:30 AM
Yes, you'll need to count.
I think about mid-late 1976 they dropped the 2 early style mount bolt bosses and used the 3 bosses with the newer mounts.
Old 04-07-2005, 07:06 AM
Brock Brock is offline
Teacher, Teacher! when you figure it out let me know, I plan to drop a 76 block in a 69 GTO in a couple of weeks and these emails casued me to get out a calculator.
