Old 05-09-2003, 11:41 AM
loup loup is offline
Hi,
I want to use a mech. fuel pump with a 1/2 fuel line (rear to front). My engine produces 400 hp and is street used.
Is it correct to join a 1/2 line to a smaller inlet of a pump (3/8 or 1/4) or the best is to enlarge the inlet of the pump ?
If this 1/2 inlet pump that doesn't require regulator exists (6-8 psi ), let me know.
Thanks.
Hi,
Thanks.
Old 05-09-2003, 12:54 PM
critter's Avatar
critter critter is offline
I'd say you're going to have a hard time moving that volume of fuel with a mechanical. You might consider an electric "pusher" pump back at the tank.
12.84 @ 106.89 with street radials.
12.63 @ 108.39 on drag radials.
Old 05-09-2003, 01:18 PM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
400 HP? You dont need anything more than the stock fuel system. Beleive it or not a guy here races a 70 judge that has run a best of 10.94 with a bone stock fuel system. Hes making close to 600 HP. Spend your money elsewhere.
Old 05-09-2003, 01:35 PM
dh_gto dh_gto is offline
I agree with Bruce. My car just dynoed at 420 hp at the rear wheels and I am just using the stock fuel line setup with a Carter mechanical pump..no problems.
Old 05-09-2003, 03:30 PM
Really need to looks at the fact that it might be hard to keep the Bowl full on your carb especially if its a Q-Jet, they are the worst to keep full, and a Mechanical pump might not do the job.
Mike
