Old 04-04-2005, 05:28 PM
ofm7432 ofm7432 is offline
When a fuel cell and battery are located in the trunk is there a specific thickness of metal needed to use behind the backseat and on top of the package tray? Also does it have to be sheet metal or can it be aluminum?
Hard, Straight and Fast
Old 04-04-2005, 06:21 PM
johnta1 johnta1 is online now
.024" steel or .032" aluminum
Old 04-05-2005, 12:14 AM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Also, remember in some cars at least there is a quite direct path open from the trunk area to the rear quarter window area, if you remove the quarter windows and mechanisms and replace them with fixed Lexan ewindows. When I sealed off the trunk in my '64 GTO, I welded some sheet metal into the bottoms of the rear quarter window openings (it's hard to describe the openings, but if you check in the area where the quarter windows are, you'll see what I mean). Maybe I'm neurotic, but I don't like the idea of sharing the passenger compartment with a bunch of race fuel.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 04-05-2005, 04:37 AM
tikiklubracing's Avatar
tikiklubracing tikiklubracing is offline
Johnta1; You are correct sir.
NHRA tech.
"Its just a 412, I swear it".
Pontiac tip of the year, quit those damn cigarettes.
