Old 06-16-2002, 11:33 PM
norton70 norton70 is offline
how hard is this to do, i am considering pulling to try and keep cooler, 400/auto, air has been removed.
Old 06-17-2002, 09:59 PM
Forrest's Avatar
Forrest Forrest is offline
not too difficult, you will have to pull the rad. and the rad shroud, then you will have to unbolt the condensor from the rad support(and any hoses ect...), gaining access from the top of and through the rad support , the condensor will come out in the same direction as the rad, strongly recommend removing the fan so you dont damage the rad. or the cond. if there is no debris inbetween the rad and cond,( blow it out with compressed air anyway) I would not worry about pulling the cond. out, your car should run at optimum ( normal) temp even with the cond. in
