Old 01-02-2003, 01:00 PM
loggy loggy is offline
I am a novice regarding installation of an oil-volts and water temp gauge for my GTO.
Can anyone advise exactly where on the engine
are the " hook up" points for the Volts,
water and temperature ?
These are electrical gauges.
Appreciate any help
[email protected]
Appreciate any help
[email protected]
Old 01-09-2003, 07:46 PM
george kujanski's Avatar
Oil pressure and water temp gauges are connected to sending units on the engine. The water temp sender goes into a pipe-threaded hole in the cylinder head whereas the oil pressure sender screws into a pipe-threaded hole in the oil filter adapter. The gauges also need a 12V source of power; the under dash ignition circuit is a good place. The voltmeter simply can connect to the ignition circuit under the dash also.
Regards, George
