Old 12-28-2002, 07:27 AM
AIR RAM AIR RAM is offline
I was just curious about O-Ringing the heads and block.
I plan to run 12:1 .040 455. It could have anywhere from 550ftTQ-600ftTQ at 3000RPM and shifting at/around 5800RPM. I have yet to pick a Roller CAM. I will be using a stall speed no higher than 3000 to keep some street-ability. 700R4 Trans, Eaton 4:10 (I know too much gear), 69 Firbird Conv.
-First would I even need to O-RING?
-Does the block and heads need to be o-ringed?
-Are there special gaskets needed?
-Is it worth it?
-Pros vs. Cons?
[img]/infopop/emoticons/icon_rolleyes.gif[/img]
SPEED SAFE, AIR RAM
Im putting together a .040 455 with Edelbrock heads (72cc), Eagle Rods, FLAT top J&E Pistons for 12:1, Harland sharp roller Rockers, Fluidampner, Edelbrock Performer RPM intake, and 750 Demon Carb. "GOT TRACTION"
"The grass is not greener on the other side, its just fertilized with different $h!t"
-Is it worth it?
-Pros vs. Cons?
SPEED SAFE, AIR RAM
Old 12-28-2002, 08:32 AM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
I figured the need for o-ringing was when 14:1 or more compression or NOS was being used. I may be wrong. I run 12.4:1 and eheads but no o-rings. In fact, I had the heads off for 3 months and re used the Fel Pro gaskets and its still going.
Wang whats with all the pictures it a parking lot.....
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 12-28-2002, 11:10 AM
Bill Meyer's Avatar
Bill Meyer Bill Meyer is offline
Location: West St Paul MN/Mesa,AZ- depending on weather
I agree with Jack. 3 years at 13:1 w/680 HP, and no head gasket problems running Felpro 1016's. Now, if your planning nitrous, that's another story---- Bill
GT37 3600lbs...as featured on the cover of Pontiac Enthusiast Jan/Feb 2002 DOT/mufflers-all motor
6.49 @ 108
10.14 @ 133
GT37 3625lbs..Fastest bench seat, column shift, all steel,no power adders car at Norwalk
1.35 w/29.5x10.5x15
6.42 @ 109
10.09 @ 133
Old 12-28-2002, 03:05 PM
Thanks guys, Thats money I can spend els where.
SPEED SAFE, AIR RAM
Old 12-28-2002, 03:56 PM
Goatman Goatman is offline
On Vacation
I o-ringed my block at 12:1 with the Butler gaskets, just in case. Having one less head bolt per cylinder than the bowtie crowd makes me nervous.
Chance favors the prepared mind.
Old 12-28-2002, 05:49 PM
Bad-Goat Bad-Goat is offline
12.5 compression making 665 hp 620lbs torque using the Felpro #1016. No problems ever!
