I have a 67 gto with air and plan on replacing existing insert as it is cracked and lifting off in spots. I've bought one from year one and before I change are there any tricks I should know about removing any of the dash mounted knobs and swicthes? thanks/
well, you probably could have saved some coin by buying PY, but anyway...I'll try to do my best and what I might miss someone else will catch.
1.remove the radio knobs and radio, knobs pull off, and retaining nuts' ratchet/wrench off.ontop of the radio should be a mount bracket that needs to be removed as well. 2. A/C control panel has 4 nut on the outer 4 corners kind of hard to get to, but they are accessable. 3. Light switch inside the dash has a spring button on the driver side of the switch that needs to be pushed as you pull on the knob towards you. 4.Ignition switch has to be removed, there is a small hole on the face next to the key slot that with the help of a paper clip or such inserted as you turn your key to acc. will release the tumbler, then you can remove the outer bezel from the switch housing. 5.wiper switch is removed by( I might need some help with this one) pulling the knob off and unscrewing the bezel. hope it helps good luck. |
