Old 04-01-2005, 06:56 PM
ofm7432 ofm7432 is offline
Does anybody have a different idea on mounting a dual electric fan on an aluminum radiator besides the plastic tie straps or welding brackets on to the radiator? The plastic strap's keep coming loose and I really don't want to weld on my expensive alum. radiator.
Hard, Straight and Fast
Old 04-02-2005, 07:05 AM
riv80 riv80 is offline
If you have say 1" more that the fan thickness to play with, I have found a way to fabricate a very simple shroud to which you attach the fans. I did it with two 12s. Check out the spal twin setup, its like that. If you are interested, I E mail you pics. I have trouble posting pics here for some reason.
Old 04-02-2005, 06:07 PM
Thanks Jim, it sounds close but I may have enough room. If you could send the pics I would appreciate it. E-mail to: [email protected] Thanks again!
Old 04-06-2005, 01:14 PM
Dave Schiffers's Avatar
Dave Schiffers Dave Schiffers is offline
jim59
I'd also appreciate the photos. If you could e-mail them to me also, that would be great. Thanks,
Dave.
Old 04-06-2005, 08:26 PM
OK Grump, they're on the way.
Old 04-09-2005, 07:18 AM
Thanks Jim
Old 04-09-2005, 09:54 AM
Steve C. Steve C. is offline
Be Cool markets a very nice bracket kit for the Spal electric fan but maybe it can be used on other brands if adapted. The mounts clip over the radiator and use slots to position the electric fan in the appropriate position.
http://www.Becool.com
Old information here:
