Old 07-24-2005, 12:54 PM
ajorda14 ajorda14 is offline
do pontiac engines sound different than chevy/ford engines? Or is it the same tone.
I know you can tell small block and big block chevy tone a bit. But I was wondering, is Pontiac a unique sound as well?
If you were blindfolded could you tell the difference between a Chevy big block and pontiac 400??
I'm just curious
67' bird
Old 07-24-2005, 03:56 PM
Schurkey Schurkey is offline
First Guess: The sound of the fuel burning in the cylinders isn't a bit different between Chevy Big Block, Pontiac, Olds, MG, Toyota, whatever--except for the displacement and the RPM involved.
Everything after that-valve timing, port shape, exhaust manifold/headers, exhaust tubes, muffler, tailpipes, etc., has it's own effect on the characteristics of the noise emitted.
Change the exhaust systems, and two Pontiac 400s will not sound the same.
Old 07-24-2005, 04:27 PM
Mach5 Mach5 is offline
I can tell a difference between a BBC and a Pontiac in the way they sound under hard acceleration...like the dragstrip.
I always thought that the engine with the most distinctive sound was the Olds V8...it had almost a burbling sound to the exhaust.
Old 07-24-2005, 04:34 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
I know the high compression motors I have built(13.5/1) had more of a "crackle" sound than my pump gas 463(9.9/1). I really like the sound of my 3" Pypes exhaust and Xcellerator mufflers. When I added the X it seemed to mellow the tone somewhat. -Jim
Old 07-24-2005, 04:50 PM
JohnnyC JohnnyC is offline
I have always been able to tell the difference in the sound of a 427 vette between a 428 ford for example. I think chevy engines have a pretty distinct sound like the 427 with solid lifters and the ls6 454 both have distinctive idles,,,, so does a 426 hemi. i think its much harder to distinguish between small block and more mass produced engines, but some of the special ones always seem to stick out above the rest
Old 07-24-2005, 04:52 PM
79firebird_99TA's Avatar
79firebird_99TA 79firebird_99TA is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by hot67bird:
I'm just curious </div></BLOCKQUOTE>
They sound pretty good if you ask me!
http://heath5.homelinux.net/firebird/lopey_bird.wav
79 Firebird/`70 400 with `77 6x-4s shaved .065"/4 speed BW ST-10/Cliff Q-Jet/XE268/3.08
99 Trans Am/383 LS1/TSP headers and catback/custom grind cam/Vigilante 2500/Strano springs and Konis
08 Corvette - Base
(SOLD) 75 Corvette/L48 350 (LSx -4L60E one day)
Old 07-24-2005, 08:43 PM
lethal-428-lemans's Avatar
The old nail head Buick had a very unique sound.
Patrick
Old 07-24-2005, 08:57 PM
Brandi Kay's Avatar
Brandi Kay Brandi Kay is offline
i love how pontiacs sound
Keepin it real in 2025.
'just another time traveler...
:range r:
Old 07-24-2005, 10:21 PM
uneasyrider's Avatar
uneasyrider uneasyrider is offline
I know that back in the '70's and before that I could tell the difference between the different stock cars going down the road. Mopars always had a real distinctive sound to me. My buddys Roadrunner has a Mopar sound to it even with headers and a far from stock cam. I'm not sure but I think the X-pipe made my TA sound less "Pontiac" than it did. It sounds more like a built 5.0 Mustang to me now. Kind'a odd. It's all about resonance frequency I wouldn't doubt that if you change the cam, heads, and exhaust enough you can lose that "original" sound.
Uneasyrider
“To find yourself, think for yourself.”
― Socrates
“The unexamined life is not worth living.”
― Socrates
“Wise men speak because they have something to say; fools because they have to say something.”
― Plato
Old 07-25-2005, 05:43 AM
Mr. P-Body Mr. P-Body is offline
Chamber shapes can affect the sound. The biggest influence winth the Pontiac is the exhaust crossover in the heads/intake. If you "fill" the crossover, the sound changes dramatically, making it sound a lot like BBC.
Old 07-25-2005, 06:26 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Mr. P-Body:
Chamber shapes can affect the sound. The biggest influence winth the Pontiac is the exhaust crossover in the heads/intake. If you "fill" the crossover, the sound changes dramatically, making it sound a lot like BBC. </div></BLOCKQUOTE>
I wouldn't doubt that your right on that. I forgot about that crossover.
Uneasyrider
― Socrates
― Socrates
― Plato
Old 07-26-2005, 12:44 PM
nikivee1954 nikivee1954 is offline
Pontiac engines definetly sound different. I can always tell a Pontiac engine from a Chevy engine. The pontiac tone is deeper than a chevy.
Old 07-26-2005, 02:12 PM
73LeMans's Avatar
73LeMans 73LeMans is offline
I asked this question when I was new to the board was well... check out the responses.
http://forums.performanceyears.com/groupee/forums/a/tpc...676070321#1676070321
Mark S
Who needs nice and pretty, when you can have mean and nasty?
KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs
So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....and 2023....and 2024.....and 2025.....who am I kidding? there will be no 9s with this engine!
>>My 73 Build thread
Old 07-26-2005, 03:46 PM
60man's Avatar
60man 60man is offline
....maybe the BBC sounds a lot like a Pontiac...
ECM member.
MANDRA
Old 07-26-2005, 04:05 PM
Dragncar Dragncar is offline
All of the old V8s had their own sound,you can hear a Olds 455 comming from a mile away,Pontiacs have their own sound,it is one of their strong points.Great sounding engines,a Tri Power with the accelerator mashed to to floor is always a good thing.Fill the crossovers and they sound even better.Most BBCs sound like crap to me.454s sound worse than 427s.
Old 07-26-2005, 05:35 PM
JEFF KING's Avatar
JEFF KING JEFF KING is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by dragncar:
All of the old V8s had their own sound,you can hear a Olds 455 comming from a mile away,Pontiacs have their own sound,it is one of their strong points.Great sounding engines,a Tri Power with the accelerator mashed to to floor is always a good thing.Fill the crossovers and they sound even better.Most BBCs sound like crap to me.454s sound worse than 427s. </div></BLOCKQUOTE>
I don,t know about that some or most BBCHEVYS sound great.
Almost as good as a worked Pontiac Engine
"And he Asked, Who Owns This Car? With The Peace Sign, Mag Wheels, and the Four on the Floor??
