Old 03-21-2005, 09:53 AM
Ovanda Ovanda is offline
I'm looking for engine mounts for my 1963 pontiac lemans-326 and an instrument cluster. Can you tell me where I can get them. I want new but will settle for what I can get.
Old 03-21-2005, 10:16 AM
SD421's Avatar
SD421 SD421 is offline
I believe those motor mounts are the same as the regular production V8 motor mounts. 1964
GTO motor mounts will do. As far as an instrument cluster Id call Ken Freeman at East/West Auto in Oklahoma. It wont be new. www.littleindians.com has him listed in the middle of the home page.
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 03-21-2005, 06:40 PM
KJB's Avatar
KJB KJB is offline
Steele Rubber has them. Go to www.steelerubber.com. Part number is 27-0108-11. Right and left side are the same. Price is $32.60 each. I bought mine from them.
Old 03-23-2005, 08:51 AM
redeyedfly's Avatar
redeyedfly redeyedfly is offline
This place has the instrument cluster.
http://www.mrgusa.com/pdfs/RechromeGM26-33.pdf
If you are looking for the actual insruments I have a couple I could sell you.
Old 03-23-2005, 02:29 PM
Anselcop Anselcop is offline
Redeye,
What type of quality are those dash bezels??? It looks like I need to send in a core and they will re-plate and paint it?
Dan
1969 Ram Air III 4-speed
1963 Lemans Convert #'s Matching 326 V-8
1949 Pontiac Silver Streak
Old 03-23-2005, 05:15 PM
redeyedfly's Avatar
I don't know. I haven't ordered from them yet. This is from my massive library of parts sources yet to be used.
Old 03-23-2005, 07:02 PM
Stuart's Avatar
Stuart Stuart is offline
I've heard of people who've had problems with Mr. G's quality and service, but I got a replated dash bezel from them for my '66 F**d pickup truck and was happy with it. Turnaround was fast and it looked very good.
Old 03-29-2005, 09:27 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
I had some thin metal rings laser cut out of 304 stainless steel the other day, the exact diameter of the raised edge of all 4 circles.
They look great & saves time from pulling the bezel. not for somebody doing al all-out show car, but for a driver they look a lot better than the old faded yellow plastic!
Peter Serio
Owner, Precision Pontiac
Old 03-29-2005, 09:29 PM
Here is the same bezel with the rings in-place.
I used a little drop of super glue at noon, 3, 6 & 9 o'clock to hold the rings on.
Peter Serio
Old 04-08-2005, 03:19 AM
gwalters gwalters is offline
Can you post a source for those laser cut rings? Any the Cost?
Old 04-09-2005, 01:34 PM
Hi, When I had mine cut for my 2 cars I had the guy make a couple extra sets for me at the same time. I would be hally to sell you a set of 4 rings for $49 postpaid.
I am not trying to get rich off fo this deal, just trying to recover some of my set-up costs to get them measured & made.
Thanks, Pete
Peter Serio
Old 04-09-2005, 01:36 PM
My website address is www.precisionpontiac.com
Here is a photo of one of my cars, it in for a total restoration right now.
Pete
Peter Serio
Old 04-12-2005, 07:05 AM
redeyedfly's Avatar
I must be a little confused here. Why spend $50 for rings that make the rest of the bezel look like crap. You can get the whole thing rechromed for $120. What do you do about the rest of the faded chrome on that bezel?
Old 04-12-2005, 09:43 AM
Hi, thanks for the support & comments, the photos above were just meant to show you my idea. ONLY.
NOTE: My photo was NEVER MEANT to represent a finshed product, ready to instal!
BTW, how much more of the bezel needs to be visible with chrome plating showing thru?
Peter Serio
Old 04-12-2005, 01:01 PM
redeyedfly's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Peter Serio:
BTW, how much more of the bezel needs to be visible with chrome plating showing thru? </div></BLOCKQUOTE>
Everything else that is chrome plated in your photo. From the drivers position, nearly everything you see is chrome plated.
How do you plan to finish the bezel?
Old 04-12-2005, 02:02 PM
63 lemans 63 lemans is offline
Peter Serio I thing your rings look great and thanks for posting some pic Il pay $50.00 for them
Old 04-13-2005, 08:36 PM
Does anyone out there in 63 Tempest-land have an NOS dash Bezel? if you could post a photo we could all see what is chrome, & what parts are painted. Going by the 15 or 20 cars I have looked at in the past year or so all that I can see that's left in bright accent chrome on the bezel are the 4 rings & the thin raised edges around the turn signal light(oval) & the high-beam indicator.
On all of the original cars I have looked at the rest of the bezel appears to me to be painted silver, (the facing with the lines in it) & then the entire rest of the bezels are all painted the interior color, (the top, lip, sides & edges). Or am I missing something here??
Peter Serio
Old 04-14-2005, 09:18 AM
redeyedfly's Avatar
I think you might be missing something. From old product literature it appears to be chromed. It is a little hard to tell since it is in black and white but you can pretty clearly make out the sparkle.
In addition I have a LeMans from Sacremento. The entire top of the bezel is missing paint from years of baking in the sun. Under the paint is remnants of the original chromed surface.
And, plastic plating techniques would make it almost impossible to plate just the top of those rings.
Upon even further investigation of this I asked my mother. Yup, my mother. She had a 63 Lemans in 65 and quite clearly remembered it to have a shiny dash.
I didn't mean to come off as harsh on you Pete. I was just looking for a clarification. I truly thought I must have been missing something.
Old 04-14-2005, 08:17 PM
One of my parts cars is a 63 Hardtop Lemans, the car is about 97% original with 90K on the odometer. The interior color is black. I know that the 1960s era process to get a chrome look to the rings was to chrome the entire part, & then detail mask & paint what they did not want to show off as chrome. On my black car which has never been altered from stock on the inside as far as I can tell, it appears that the background of the dash, where there are a series of parallel lines that all run left to right (behind) the 4 round openings. On all my cars this appears to be factory painted a dull silver color. All my cars appear to have silver paint on top of the chrome in this background area. Any comments from other members on this?
Peter Serio
