Closed Thread
Old 09-17-2000, 09:51 PM
GregV GregV is offline
Ok I hope you guys can help me. I gotta crack in the outer water jacket of the engine block about 2 inches long. It just barely seeps at 18 psi coolant pressure. How do i repair this? weld or braze and will either be sucessful? Helpppppppp!!!!!!!!
[email protected]
[email protected]
[email protected]
[email protected]
Old 09-18-2000, 08:39 AM
you'll laugh at this but if you clean the block well jb weld will hold. crown welding eqpt markets an arc rod that works well on cast without the preheating. i think the # is 255, check with a welding shop to be sure.
if you weld it you'll want to drill a small hole in both ends of the crack to stop it from spreading. mike
[This message has been edited by mike nixon (edited 09-18-2000).]
former." --Albert Einstein
- Winston Churchill
Old 09-18-2000, 10:55 AM
Ccass's Avatar
Ccass Ccass is offline
Administrator
moving topic to "Drivetrain-street"
Closed Thread
