Old 04-12-2005, 03:14 PM
pontiacjim pontiacjim is offline
I'm thinking about trying to replace the stock 69 rear with a disc brake rear. Has anyone tried this before ? Would like to know what doner car to start with. Any thoughts ?
Jim
Jim
Old 04-12-2005, 07:14 PM
68alpinebluegto 68alpinebluegto is offline
The easiest thing to do is buy a JL8 factory disc brake rear end from a 69 Camaro. Bolts right in... the problem being that the rear end runs about $10,000...YES that is the correct number of Zeros in there.
Survivors, frameoffs etc http://community.webshots.com/user/firstgenaddict
68 GTO HO 4spd Alpine Blue over Parchment headrest (paused while I restore other people's cars)
70 Judge Conv. RAIII 4spd 4.33 I painted for a friend. http://rides.webshots.com/album/187328041oxAXRI
Old 04-13-2005, 07:19 AM
69fireburger 69fireburger is offline
I believe you can use a rear from a second gen. F-body. You need the get the first gen. spring perches welded onto it. Take measurements to be sure...but I thought I read that this had been done before.
--Bob
Old 04-13-2005, 08:35 AM
Lee's Avatar
Lee Lee is offline
The 2nd gen rear disc setup is CRAP, though! It uses an emergency-brake activated, ratchet adjustment systment system. It was quite common to have on caliper lock under light pedal, while the other wouldn't lock at all. If you didn't regularly use the e-brake, and FULLY activate it when you did, your rear brakes would get less and less effective as the pads wore.
Go with one of the aftermarket kits that offers modern calipers that adjust properly.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 04-15-2005, 12:30 PM
pontiac_banshee's Avatar
pontiac_banshee pontiac_banshee is offline
On ebay there is a company that sells a bolt on bracket for your 10/12 bolt.
Then you buy rotors (rear) for a 1980 Firebird
Then you buy rear calipers from Caddilac Seviles
Do some searches on this site and you will find this setup. The guy that sells the mounts sells complete kits for $499.
Old 04-15-2005, 02:36 PM
MikeNoun's Avatar
MikeNoun MikeNoun is offline
Timing is everything...
Check out the new Musclecar Enthusiast Magazine that just came out. They have a feature story on installing rear disc brakes on a 69 Trans Am clone.
Old 04-17-2005, 08:53 AM
Thanks Guys
This is the best place to come to for info.
Jim
