Old 12-06-2000, 11:19 PM
Mike Mike is offline
I have a 66 GTO 3.55 Rear end, What lube is used? Do I need to add a additive? How much? Thanks!
Old 12-06-2000, 11:44 PM
Blackcat's Avatar
Blackcat Blackcat is offline
Bonker's-T-Cat Moderator
Most Auto parts stores have Gearlube. 75-90 or 80-to 120 weight. Same stuff for manual transmissions for early Pontiacs. Yes, You will need additive for the Posi. Check your dealership or PY sells it. Without it the rear will chatter around the corners.
Gatomon
A car is cheaper than a girlfriend. Better than a wife. If it gives you trouble you can park it and forget about it!
Try calling CRUSHPROOF! 512-386-9889
