Old 04-22-2002, 04:44 PM
Jonas sweden Jonas sweden is offline
Hi!
I don´t know if i should by edelbrock intage manifold and carburetor or a Holley. I have a 326 engine, and should have 600 cmf. Can someone help me to coose right ???.
Jonas
Hi!
Jonas
Old 04-22-2002, 05:43 PM
Ccass's Avatar
Ccass Ccass is offline
Administrator
Jonas, Can you get your hands on a factory 64-66 or 67-70 cast iron 4 bbl intake and Carter AFB or Q-jet carb?
Old 04-22-2002, 07:00 PM
Blackcat's Avatar
Blackcat Blackcat is offline
Bonker's-T-Cat Moderator
Running the Factory 4-bbl for a 65-66 and a AFB is a good combo. The next best is a 67-71 Q-jet and a Quad for a Pontiac 350.
Try calling CRUSHPROOF! 512-386-9889
Old 04-22-2002, 09:16 PM
carbking's Avatar
carbking carbking is offline
Blackcat, like your two choices; but just my opinion, would flipflop the order. Reason - the smaller primary on the Q-Jet (vis-a-vis the AFB) would provide better low end velocity on the 326. Either might need a slightly richer calibration on the 326. Jon.
Old 04-22-2002, 09:43 PM
Blackcat's Avatar
The two biggest problems I run across is.
Over canning.
Over carboration!
The Q-jet is the better choice but One has to make sure that the Jetting is for a 350. I've had people come buy with the Huge jets on the carbs and wonder where the milage went!
