Old 05-07-2005, 02:09 PM
Derding's Avatar
Derding Derding is offline
In my front disc conversion kit for my 68 Firebird from Inline Tube, there are 2 copper washers twist tied to each of the calipers. What are these for?
Derding's Avatar
Old 05-07-2005, 04:25 PM
pro-tour79's Avatar
pro-tour79 pro-tour79 is offline
gaskets for the bango fittings, they have groves around them right!?
www.pro-touringf-body.com
Old 05-07-2005, 04:36 PM
Derding's Avatar
They don't look like they have grooves, but they are slightly tapperd. What is the banjo fitting?
Old 05-07-2005, 05:18 PM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
It is the bolt that goes through the brass fitting on teh end of the brake hose that connects to the caliper.
Old 05-08-2005, 09:40 AM
GoatDr GoatDr is offline
The mating surface of the brake hose is grooved and once the washers/bolt are torqued down it compresses the copper and makes the grooves in the copper sealing the brake fitting.
GoatDr
Old 05-09-2005, 06:11 AM
bobbyj1's Avatar
bobbyj1 bobbyj1 is offline
I believe one goes on either side of the brake line fitting. I am sure someone else can verify this
67 GTO Hardtop
Old 05-09-2005, 09:27 AM
george kujanski's Avatar
One washer seals to bolt head to the fitting, the second seals the fitting to the caliper.
george
