Old 02-14-2003, 07:15 AM
Dalton 66 GTO Dalton 66 GTO is offline
I just replaced my water pump, thermostat(180 degrees), and had my radiator boiled on my 66 Tempest with a 3 core radiator and a 326. Now, I can only fill it with a gallon and a half of coolant. It looks like the radiator isn't circulating. It isn't moving around in there. The coolant does get hot and both heater hoses are hot with hot air blows inside, but there is no pressure in the top hose. I have left the cap off waiting for the coolant level to drop so I can add more as it begins circulating, but it hasn't dropped.
Do you think it's a bad thermostat? Could there be a pressure lock in the cooling system somewhere?
Old 02-14-2003, 07:58 AM
AIR RAM AIR RAM is offline
Pull the t-stat and throw it into a pan of water (on the stove) and watch it as it heats up. with a temp guage take note of the temperature the state opens. I have found several t-stats defective. I have had 180 stats open as 160 and 190 stats not open at all. There is a few that get through the cracks as QA is watching.
You could just buy another one and see if that works, but you would never know what the actual temp of your t-stat is.
SPEED SAFE, AIR RAM
Im putting together a .040 455 with Edelbrock heads (72cc), Eagle Rods, FLAT top J&E Pistons for 12:1, Harland sharp roller Rockers, Fluidampner, Edelbrock Performer RPM intake, and 750 Demon Carb. "GOT TRACTION"
"The grass is not greener on the other side, its just fertilized with different $h!t"
Old 02-14-2003, 08:00 AM
78 GHOST 78 GHOST is offline
My thoughts exactly Air Ram. I had two brand new NAPA 'stats that were opening late (200-210 on a 160 'stat.)
Upper hose unpressurized means the 'stat is still closed.
____________________________________
"Gee, what's that goat doing way up here in a cloud?" -Gary Larson
TO THE MILITARY FORCES CURRENTLY ACTIVE, AND THOSE THAT HAVE SERVED; THANK YOU FOR YOUR SACRIFICE FOR FREEDOM. PLEASE COME HOME SAFE.
"I work in high speed aluminum tubing."
Old 02-14-2003, 09:12 AM
Thanks guys, I'll give it a shot...
Old 02-15-2003, 12:43 PM
Huss Meister Huss Meister is offline
Hey If you dont want to boil the t stat..you can just remove it and bolt the water neck down without it and then see if you get instant water movement.
Old 02-15-2003, 06:29 PM
Dave Schiffers's Avatar
Dave Schiffers Dave Schiffers is offline
Always boil a stat before installing to confirm opening.
Also boil with a temp guage or thermometer to get opening temp and compare with guage in car to note difference.
