Old 04-04-2000, 11:59 PM
Goatin Goatin is offline
Have a 65 tempest wagon. When you roll down the rear window their is a metal suport inside the door that rides right on the glass and has scratched the glass. Question: is that support needed is thier a fix that some one might know
Old 04-24-2000, 06:07 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
If it's what I am thinking of; that bracket is meant to rub the glass and to prevent any rattles. From the factory it was covered with a "fuzzy" felt strip that was glued on with contact cement. If you need the strip I think I have an NOS piece of it, the strip will wear off or fall off over time and I think that is what has happened with yours.
Peter Serio
Owner, Precision Pontiac
Peter Serio
Old 05-01-2000, 02:49 PM
try buffing the glass with a compound called jewelers rouge. this is an ultrafine grit and works well on glass if the damage isn't too deep. mike
former." --Albert Einstein
- Winston Churchill
