Old 10-06-2001, 03:43 PM
GoatFever GoatFever is offline
I want to swap out my turbo 350 for
a turbo 400 his/hers on my 1967 Lemans. What parts will I need. Is the trans crossmember the same?
Driveshaft? etc. Appreciate any help from
someone who has done the conversion.
1968 Firebird Convertible
Montego Magenta
1967 GTO Convertible Tyrol Blue
1967 GTO Hardtop- Fathom Blue
"Got Pontiac"
Montego Magenta
"Got Pontiac"
Old 10-07-2001, 10:04 AM
'65-67 Tempest, LeMans & GTO 2spd auto & 4speed driveshaft dimensions, 60.00" u-joint center to u-joint center.
'67 GTO Turbo 400 driveshaft dimensions, 59.375" u-joint center to u-joint center, used short T400 yoke with splines not starting until 3/8" up in the yoke. This is dimensions for use with factory short tail T400, NOT big car T400's.
Will have to slide the crossmember forward, multiple holes are there to bolt it down. Good luck.
