Ok, here's the scoop. This spring I decided to replace the floor pans in my 64 Tempest. I got the floors cut out and then the city cited me and told me I had to paint the garage. I spent a good month doing that. Back to the car. I have never welded before in my life, so between baseball games and family functions I was able to put this back together and painted the floor. I've stood in it, seems solid so I am happy. Here's the problem, I turned on the lights just to check them. I had no outside lights front or back and no brake lights. Only dome light and dash lights. I turned the key, it cranked, I pumped the gas, I turned the key again and it cranked 3 times and saw a spark from the battery. Now I have nothing. No lights, no nothing, Battery is still charged, pulled the starter it is working off a battery charger, no resistance problems in the wires to the starter, the ignition switch seems to work.
What happened? Is there a fusible link on these cars? I am lost. Help, Please. [img]/infopop/emoticons/icon_confused.gif[/img] |
Loose connection on the batt. Pull the cables off and clean the batt. terminals. Then make sure all the connections are tight. good luck.
My Rig's a little old, but that don't mean she's slow.
WWW.PatriotGuard.org Standing for those that stood for us. Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I. One for your soul; the other for your freedom |
You need to check all your ground connections also. It is very common to overlook the ground curcuit when trouble shooting.
...best if used on or before date indicated... |
