Old 06-13-2005, 08:18 AM
Jaggs79transam Jaggs79transam is offline
Hello Everyone,
I have a 455 olds in my 79 T/A I can't keep a charge on the battery though!!
New starter, new alternator, new battery, new cables, and every other part that throws power.
I tested all these parts and they are throwing proper current.
I can charge the batter and start the car fine. but after sitting for about 3 hours the battery gets too low to crank.
Any Ideas where I should look?
Thanks in advance for any help!!
Jaggs
[email protected]
1979 Trans Am 455 Olds, 2500 stall
Old 06-19-2005, 12:19 PM
To kill the battery in 3 hours there has to be a hell of a drain. Forget the radio or interior lights. Check the brake lights and see if they are staying on. You have something that draws a lot of amps. Start checking for something that is staying on.
Old 06-19-2005, 07:04 PM
oldblueponcho's Avatar
oldblueponcho oldblueponcho is offline
Bad diodes in the alternator can make it drain back fast. To check easy & fast, unhook the batt ground wire. if you get a spark you have current.then unhook alt wires. if spark are gone when you touch ground wire to post, the alt is the problem. If no spark then the next step is to get your batt load tested.Maybe it's just hooped & won't hold a charge.
Some Fear, Because if you've never been afraid- just a little. You're obviously not going as fast as you could be.
Old 07-17-2005, 08:28 AM
Thanks guys It was In the brakes.
I never noticed because I was always up front.
Jaggs
