Old 06-18-2001, 09:23 PM
Eric Schattschneider Eric Schattschneider is offline
What is the difference btwn the two when repainting/redying interior parts? What is the difference btwn the 2 and what is better.
thanks,
eric
thanks,
eric
Old 06-19-2001, 06:02 AM
jim darlington jim darlington is offline
Use the vinyl dye . It will give you much better results . It's always good to clean the vinyl or plastic panels with lacquer thinner first . Vinyl dye is more flexible the lacquer .
Man is not complete until he's married , then he is finished !
Old 06-20-2001, 03:21 PM
So does the vinyl dye go into the plastic? What makes it better?
Old 06-20-2001, 08:27 PM
JC455 JC455 is offline
I would use the vinyl dye. You need to prep the panels with lacquer thinner or vinyl dye prep-ask your paint shop for a recomendation.
The prep product will open the pores of the material and allow the dye to saturate it better.
To me, acrylic lacquer is too prone to peeling (it is acrylic-a.k.a. plastic) and I've usually regretted not using the dye.
If I were painting a hard part- metal dash, etc.- I would use the acrylic paint, although I might prefer to go with a base/clear if I could, to achieve proper color/sheen match of the paint to the rest of the interior.
Just my thoughts...
John
John
IG: @crawdaddycustoms
YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos
