Old 05-31-2002, 02:57 PM
rodblur rodblur is offline
Hello all. I need some help. Tomorrow, I'm going to look at a '66 LeMans. It's a 3 sp m/t, 400 cu. in. motor, and it runs. The owner says it needs an exhaust, choke plate and body work. I need to know what are the areas should I concentrate on when it comes to looking for rust? Also what kind of things to stay away from.
Old 05-31-2002, 03:07 PM
Bud Lyons's Avatar
Bud Lyons Bud Lyons is offline
Send a message via MSN to Bud Lyons
Rod, Look at the front fenders. About 3" in front of the doors is a support that runs down the inside of the fender. These will rust out from the inside. Check the rear quarters. Anywhere that snow and salt could have accummulated. Check the trunk floor. 66's had a habit of leaking and rusting out the trunk.
WWW.PatriotGuard.org
Standing for those that stood for us.
Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I.
One for your soul; the other for your freedom
Old 05-31-2002, 04:50 PM
jim darlington jim darlington is offline
Bud is correct , also you want to check the frame . The torque boxes front and rear tend to rot from the inside out . The rear crossmember above the rear axle is an area you want to check for cracks . Good luck .
Man is not complete until he's married , then he is finished !
Old 05-31-2002, 09:55 PM
Thanks for all the tips guys. I have new a question. What's are torque boxes? I'd assume they are located near the trans and rear.
I think I'll be taking some pictures. That should help catch things that I may not notice. Again thanks for all your help.
Old 06-01-2002, 05:48 AM
Look at the frame in the aera of your rocker panels . Where the rocker panel panel ends front and rear , the frame will bend inward to the center of the car . At the bends is the torque box . There is 4 on a frame .
Old 06-01-2002, 11:25 AM
carcrazy carcrazy is offline
Check the area where the metal dash meets the front windshield. You should check this from above and below! Take a long hard look in the trunk under the rear glass area. I failed to check these areas closely and got a very unpleasant suprise!
Good Luck!
Old 06-02-2002, 06:48 AM
dallas dallas is offline
Better take a magnet with you for the body panels. If a decent prep man covered up a big bondo job you wouldn't see with faded paint or primer. Stick a magnet (even a refrigerator magnet will do) on the body all around the car. The bad stuff is blisters, bubbles and holes, but they don't always show from the surface. That's where I start thumping panels.
Ditto to all the places everyone mentioned, especially around the window frames. I always figure if the car has rust up high, chances are reeeeeal good that there's rust down below.
A life spent making mistakes is not only more honorable but more useful than a life spent doing nothing (G.B.Shaw). At least that's my excuse.
