Old 08-29-2002, 04:27 PM
ta406pont ta406pont is offline
O.K here's a simple question for you guy's,how much does a complete 400 engine weigh carb-oilpan??
I want to order some Moroso Trick front springs,but the car currently has a Buick 455 in it,and I'm pretty sure they don't weigh the same,I see they list springs for Camaro only with a Big Block Chevy or a Sm Block,so the question is which ones do I get for my T/A??
thanks for any help
Rob..
[ August 29, 2002, 04:28 PM: Message edited by: 80pont406 ]
thanks for any help
Rob..
Old 08-29-2002, 06:00 PM
Goatman Goatman is offline
On Vacation
If you have an all steel car with some power accessories, go with the BB springs. If you have a lightweight car carrying just the motor, go with the small block springs.
Word of caution: Let the car sit for a couple of weeks before you trim the springs. They will sink quite a bit (mine almost sank 5 inches). I know of two guys already that didn't want to wait, and now they have their headers on the ground.
[ August 29, 2002, 06:01 PM: Message edited by: Goatman ]
Old 08-29-2002, 07:17 PM
The car is all steel except for the 4" lift off cowl hood.It will be gettin lightened up a bit pretty soon.What are some ideas to take weight off the front end of the car?It's a 1979 T/A.
Thanks guy's
Rob..
Old 08-29-2002, 08:36 PM
Steve C. Steve C. is online now
The front bumper-nosepiece weighs about 398 pounds [img]smile.gif[/img]
Old information here:
Old 08-29-2002, 08:52 PM
67rs6spd 67rs6spd is offline
They both are about 640 thats what I was told awhile back 2nd hand info
Old 08-29-2002, 09:08 PM
David Holmberg's Avatar
<font size="2" face="Verdana, Helvetica, sans-serif">Steve, Mongo was standing on the scale when it was weighed...
Old 08-29-2002, 09:46 PM
On Vacation
Rob, on top of the massive front bumper supports, there are tubular control arms, lightweight brakes, aluminum radiator supports and radiators, fiberglass bumpers, aluminum steering boxes, and good old fashioned hole sawing/plasma cutting that could be done in such a way as to keep the car looking stock, but be really light.
PS
Don't forget about the 500lb door braces in those cars.
Old 08-29-2002, 10:08 PM
Brian Baker's Avatar
Actually, the front end on the 79 is not as heavy as one would think. I've had the inner bumper and frame brackets off myself at least twice and the whole assembly probably weighs between 45-65 lbs.
Old 08-29-2002, 11:02 PM
On Vacation
On the nose of a car, that is 400lbs.
Old 08-29-2002, 11:05 PM
Traditional all iron Pontiacs engines are 640-660 lbs.
KS circutguy's Avatar
80pon406
The Buik 455 was the lightest of the BB's.
Old 08-30-2002, 09:25 AM
Good morning guy's,
Thanks for all the great info guy's I really appreciate it,one question Where can I find a aluminum radiator support??I would love to have 1 of them,I see Chad Dammen made a tubular radiator support for his T/A does anyone know what he used and what the dimensions were for it??Those boat anchor door bars are definetly gonna GO .
Old 09-02-2002, 03:08 PM
Ray Cox's Avatar
Ray Cox Ray Cox is offline
a front racktakes a lot of weight off as do the other things bruce mentioned. the inner bumper and brackets brian mentioned also take a lot of weight off, if any body is interested I am having a front bar made that would replace the steel bumper it will probably bolt on in the stock location and help suport the nose, (my nose is saging terribly after taking the bumper out.) it will also have a tow hook sticking through the spoiler as well as mounts for the turnsignal & hood release. I am also thinking of haveing the entire front nose made out of glass because of the paint cracking. any body interested in these please let me know.
8.30 @ 165 mph 3,380 LBS
Old 09-02-2002, 03:10 PM
Ray Cox's Avatar
Bruce is also right about cutting the springs, it happened to me!!sunk 3" in a few days went to move it and the headers were on the ground!
Old 09-02-2002, 03:14 PM
Ray, The 77/78 Nose is about the only nose not being made. If your thinking of making one up, I'm very interested.
Keep me Posted!
Old 09-02-2002, 03:16 PM
Good info Ray I thought about having a bar made up for the nose also because I know after a while it will start to sag with nothing in there but my car is a 79 though so it's a little different than your's,your idea is a very good one though.Also as for the springs I'll take you and Bruces advice and wait a week or so before I do any cutting.
Thanks for the advice
Rob..
[ September 02, 2002, 03:18 PM: Message edited by: 80pont406 ]
Old 09-02-2002, 03:23 PM
Oh yeah I also took and weighed a 400 complete carb to pan it was 658lbs on my friend scales,just thought I'd let ya know...
Old 09-02-2002, 03:52 PM
On Vacation
Rob, if you have a good stock radiator support, I have a freind that can make you one out of aluminum. They look pretty close to stock when they are done too. We can have them powder coated or anodized as well.
Old 09-02-2002, 03:55 PM
Goatman that sounds like a pretty good idea I do have a mint radiator support for something like that or do you mean he makes radiator supports out of aluminum?, if thats the case I definetly want one,shoot me a email or something,also thanks for the info on Dick I got a hold of him today I will be bringing a set of heads down to him asap hopefully this month anyway.
[ September 02, 2002, 03:58 PM: Message edited by: 80pont406 ]
