Old 02-16-2003, 12:06 AM
69PRIX 69PRIX is offline
My 2000 montana has a bad front wheel bearing so I replaced it and just took it for a drive and after about 10 miles I started to hear a clunking in the front end.Something loosend up I will check tomorrow too see what but right now I want to see if I did anything wrong.There are 3 13mm bolts that hold the hub/bearing assembly on I torque them to 65 ftlbs with no thread locker and torqued the big driveshaft nut to 175 ftlbs also no thread locker and I reused all the bolts, was this the right way or should I have torqued differently or used some sort of locker or do you have to replace the big nut and small bolts everytime?any help will be much appreciated thanks.
Old 02-16-2003, 10:22 AM
TIAUTOMAN TIAUTOMAN is offline
Should have replaced all the bolts, and axle nut.
Didnt the new hub come with them?
Was it a Delco replacment part?
Check to see if the caliper bols are loose
Common clunk noise.
Old 02-16-2003, 07:50 PM
Travis thanks for the info I took it apart and nothing was wrong!except the new bearing I got from the parts store is junk the clunking I have going on is the bearing itself'it has side movement so tomorrow I'm going to return it and try a different bearing.thanks.
Old 02-16-2003, 09:42 PM
Spend the money, Get a Delco part.
