Old 07-02-2001, 11:30 AM
Judge Smails's Avatar
Judge Smails Judge Smails is offline
Took a peek into the door jamb vents and found some r*st starting inside the front of the 1/4 panels. Do I simply apply the standard POR-15 rust preventive paint directly on it or buy the whole kit, Marine=Clean, degreaser, metal etcher, etc.? Metal seems reasonably clean; for some reason it's also a little damp(?). Thanks.
Old 07-02-2001, 12:11 PM
steveK steveK is offline
Judge, if there is no paint on the metal area you are painting, just take some 400 grit sandpaper and go over it. Otherwise you need to remove whaterver paint is on that area as this stuff is for metal/rust coverage. You can then paint the POR-15 with a 1/2 decent paint brush but you may just want to want to thin it about 25% with laquer thinner. Do not retouch it as it dries as this will leave brush marks in the paint. Only way to get rid of those is to resand and reapply. It is tough stuff to sand too!!! I did my frame, underbody,firewall, and top floor pans with it. It came out great. You can then paint (top coat) over it any type of paint when dry and it will not rust through.
[This message has been edited by steveK (edited 07-02-2001).]
Steve Karew
Old 07-02-2001, 04:48 PM
jim darlington jim darlington is offline
Don't get any on you , it will take a week to wear off .
Man is not complete until he's married , then he is finished !
