Old 03-08-2005, 03:25 AM
FlyByNightRacing FlyByNightRacing is offline
I have here a 78? 400 block that has the odd layout for the mounts. I was told it was a 78 peice. From the looks of it, it dont look as strong as the older blocks. Has anyone had any luck with these things or should i try to find another older block? its for a bracket motor that will be about 600 HP. Thanks
Rex Caroll
Rex Caroll
Old 03-08-2005, 05:37 AM
PONTIAC DUDE's Avatar
No, keep it for a stock or mild/medium build. Weak around the lower main support area. These blocks have a tendency to crack from the dowel pins to the cam journal.
Have converted to a 455, but still has to be a rather mild/medium combo.
Old 03-08-2005, 08:53 AM
azbirds's Avatar
azbirds azbirds is offline
1970-1973 400 blocks seam to be the ticket.
When people tell me they HAD to sell their car when they started a family, I show them the three car seats in the back of my 69Trans-Am..............and we didn't even use car seats back then!!
Old 03-08-2005, 11:56 AM
fiedlerh's Avatar
fiedlerh fiedlerh is offline
The better 400 blocks are before mid-1975 which is when the 481988 casting was discontinued and replaced with thinner castings beginning with 500xxx.
http://www.pontiacpower.org/
Old 03-08-2005, 01:29 PM
tikiklubracing's Avatar
tikiklubracing tikiklubracing is offline
What would be the top rpm, for the thinner blocks.
NHRA tech.
"Its just a 412, I swear it".
Pontiac tip of the year, quit those damn cigarettes.
Old 03-09-2005, 01:08 AM
lemans411's Avatar
lemans411 lemans411 is offline
so what would be consiseded the best (strongest) or one of the best castings then #481988? or what?
rob
67 lemans
-Rob
67 LE MANS in pieces...
68 gto
84 grand prix twin turbo 496 pontiac 25.3 cage
Old 03-09-2005, 09:19 AM
fiedlerh's Avatar
I've heard that for the 2-bolt main 400 block all '67 to mid-'75 are pretty much the same. Someone also posted saying they thought the 67 block was meatier. You would have to line up all the casting numbers and check them, or talk to someone who has built hundreds of motors and knows the ins and outs of certain castings.
For example, Dan Whitmore told me '66 blocks tend to crack in the lifter valley region and quite a few 76 455 block have some of the lifter bores drilled crooked.
Old 03-09-2005, 10:33 AM
Region Warrior's Avatar
Back in the 80's, a Pontiac Engineer told me before 70 something, Pontiac used a stronger metal composition. In the early 70's, they used a softer? metal. Thicker main webb blocks were used in the HD applications when they changed metal strength. The 400ci cast# 481988 blocks are the HD's. Not sure of early 70 useage. In 78 & 79, Pontiac used alot of these in TA's (X7 & WC). They have xx on both sides of block, top rear of blk, and in the valley. I dont have the cast # for the 455 blocks.
Old 03-09-2005, 10:51 AM
ponchobob ponchobob is offline
A few years back we tried "455ing" a 76" 400" block. .680" roller cam and 14-1cr. Wound up having the most CATASROPHIC engine explosion ever seen at Milan dragway out side of top fuel!!!- Block was in 8 pieces, crank in 4,EVERY piston in the pan, and a main cap with part of block attached went through a Vega's windshield in the next lane!! Happened in the traps at 133mph! Scariest thing I had seen to that date, Glad Jeff was driving, not me! To this day, neither one of us know how he kept from rolling it. I hope this answered your question!-Bob.
