Old 03-31-2003, 12:33 AM
GTOGary GTOGary is offline
Hello everyone, Put my headers by Doug on tonight. Not too bad of an install on my 66 GTO . Does anyone have any feedback on the Bison header gaskets that come with Doug's headers. Any other recommendations? Thanks!
Old 03-31-2003, 05:53 PM
gto70 gto70 is offline
Gettin' ready to install Dougs Headers on my car as well. Did you use the supplied Bison gaskets? If so, did you also use sealer, and did they leak?
Old 04-02-2003, 12:55 AM
TO GTO70, Won't know if they leak or not until we fire up the new engine. We're about a month away from that, but I'll post the results. We did use a high temp silcone sealer......Gary
Old 04-27-2003, 03:52 PM
KGTO's Avatar
KGTO KGTO is offline
I tried getting some answers on this same topic last fall with no luck. The gaskets look to be top notch, but I ended up using the fel-pro header gaskets that come in the racing kit to be on the safe side. No leaks! I used the copper spray this time to, a lot less messier than silicone.
1967 GTO 400 4-speed (416) #62's 11:1 solid lifter 6.8 Eagle/Ross full exhaust 11.80's@116---> UPDATED, heads race ported (287/200) and extras; shooting at low 11's in the spring, 10's on spray!
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @164 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
Old 05-08-2003, 11:44 PM
Thanks for your input KGTO....Gary
