I'm toying with the idea to convert from a 4 speed to an automatic in my street/strip 65 GTO. Equal time spent racing and street driving. It's tough to keep clutches and trannys from going south. And I'm getting a little tired of tearing it apart 2 or 3 times a year for one problem or another.
Who do you recommend that makes great transmissions? What trans would you recommend? Who makes a great converter? What stall with what mods? Street manners are not a concern - to a point. My combo: 455 w/ ported 670's around 520 hp, 550 lbs. torque Solid cam, 12.1:1 Hooker headers, 3" exhaust 3.73's I've gone a best of 11.92 at 116. I know its got more in her due to the fact that it bogs a little off the line. I come off the line at 4500-5k rpm which takes it's toll on the drivetrain. Even though I love the 4 speed it's just too much work. All comments welcome. Thanks, Phil
_________________________ _________________________________ http://www.youtube.com/watch?v=_qZgOpn-w-o <<< Burnout Video ![]() ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ "Treat Me Good, I'll Treat You Better; Treat Me Bad, I'll Treat You Worse" Sonny Barger ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ |
For an out of the box converter the B&M converters work pretty good. I would go with the 10 inch 3000. If you want to spend more go with a Continental.
How Heavy is the car -- less than 3000 pound a power glide will work good -- if built strong, if it is heavier then a T/H 400 is a good choice, cheaper to build and strong, Use a good convertor -- the cheap ones will not hold up with the torque of a good Pontiac. Expect to pay 700 to 900 bucks for a good steel stator set-up.
oops! Race weight with driver = 3725 lbs.
thx
I have always had very good luck with Coan Transmission. Send the dyno sheets, gear ratio, tire size and what trans, convertors have always been dead on the rpm I wanted.
You will get all kinds of opinions. It is about like anything, whatever a guy has is best for him but maybe not for everbody else. http://www.coanracing.com/
Steve Yea, I know, the heads suck! 2005 Cordova Q16 Winner! 2005 Norwalk Sat Top ET Winner! |
Coans are ok, but a lot of money TTs can build one just as good for a lot less, the one they did for me is great, they also did one for Mike Davis in the midle of the night to keepp him in a race, put it in a few minutes before first round and went 3-4 rounds.
Paul 504 271-8767
77 Trans Am All Steel, on 10" tires 8.30 @ 165 mph 3,380 LBS Mat it! Spray it! Chute it! Just another 8 Second Pass! |
turbo 400 is what fits your catagory with 10" to 11" torque converters and 2700 to 3000 at the most stall.
now as far as brand names for trans and torque converter ,the choices ar unlimited , you can have a local reputable trans shop build you a th400 or buy just about any of the major companys that build 400 ,400's arent like overdrive 700r4 or 2004r transmissions ,where you have a better build over other builders,shop around whos got a better deal for you ,almost all performance builders use the same good parts. same aplies to torque converters. just to throw major brand names wil start with TCI and almost all whats sold in summit racing.
http://www.youtube.com/watch?v=3FfKVVZW1-Y |
Hey Phil,Its Mark from thepike.net site;with the `70 bird.I recommend Dynamic Converters in Delaware.They used to be in New Haven,then moved down to DE.I have a turbo 350 built by them back in `95,and knock on wood,has held up very well behind our 455.Tranny has never been out of the car;only moved back to do a conveter swap.We use a big Permacool tranny cooler,and run a Dynamic 8" conveter,and like I said,no problems so far.The car weighs 3650lbs with me in it.Let me know how you make out.
`70 Firebird,Original Owner car Ken French Built Chassis Carlquist Competition Engines IA2 505 Competition CNC Ported Super Chiefs CCE Ported Gustram Twin Dominators from Shaker 455 963 HP `09 Electra Glide Standard. `03 F-350 7.3 6-speed 4x4 Crew Cab Dually. |
I chose to use an ATI converter, I only have about 30 easy passes on it so far, but we are looking to push it real hard this coming season.
my trans. guy recomended it, he is the only guy I know that warrenties his race tranys'.
67 firebird, RPE built 274ci TA Performance Buick V6 block, 8.89@154.85 with just a few bolt ons, & a 275 DR. anyone can restore 1 it takes a real man to cut 1 up! 99 Western Star 500hp 52' lowboy Mid Atlantic Heavy Hauling Those Old Timers That Think... There Is No Replacement For Displacement Do Not Know What Boost Is. |
Hey Phil, what clutch/pressure plate setup are you using? what 4spd tranny as well, T-10, Muncie? what problems are you having?
1966 Lemans, 3700Lbs, 406 ci, #96 Heads, Crane 467/494 cam, RPM Intake, Q-Jet, 11 inch Converter, 3:90 gears, 3 inch exhaust, Best ET 12.62@107 MPH 414ci shortblock coming soon! |
Supercase Muncie from Liberty, RAM clutch.
The clutch problems I've had varied from: Engine oil contamination - fried clutch Wrong throw out bearing - fried clutch Overheated clutch, chattering - fried clutch My trans is whining a little in first gear right now so I'm thinking I should get it looked at before it really gets damaged. I'm presently running a stock replacement clutch that I threw in it while at Norwalk last summer. Surprisingly it has been holding up darn well and really could last a while longer if I weren't racing it a few dozen runs per season. Like I've said, I love having a 4 speed but the work involved is getting a little old - and so am I. ![]()
Phil , do you race often @ Lebannon Valley? I grew up @ that track with my cousins husband, Lenny Moore. he had a red 68 firebird, is son now races it. do you know of him? the reason I ask is the pic. under you name I reconise the starting line.
TurboPontiac - Yea that's Lebanon. I don't go there too often but his name sounds familiar. Hope to meet them and you. Where are you guys from?
BADHABT - Hey Mark! I'll look into your trans guy - thx.
Phil, Select Transmissions is close to you in West Babylon NY. They build transmissions and convertors. They ask all of your information and will custom build you a convertor specifically to your application. Being close, you can drive to them. I needed a longer crank hub on my convertor when I switched from a 1/8" to 1/4" mid plate. They said to ship it and they would get it out same day. Still would have been 3 days til I got it back. I asked if I could bring it up that day. They said yes and took care of it while I waited. Ask for Ed Sr. when you call. 888-55-SELECT
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1 |
I now live in NC I've been here for the last 15 years. I said to the wife "hey that's the valley". we haven't been up in that cold country in a few years. I did take one of my Grand Nationals up there to race it, a grudge race against Lenny. you can't miss his car it's a red 68 bird, centerline satin auto drags up front,& corvette rallys out back, with a snorkel that says Iron Indian on it.
Steve
For a turbo 400 buy from Carl Rossler.He has the best transmissions period.I own two of them and have never had a problem.For the convertor go to ATI and talk to Charlie Plot.ATI KNOWS Pontiac motors!!!
Phil for a local trans vendor there is none better than Dynamic- I think they are in east haven or branford, I'll get the info. he is big into mopars but builds great gm tranny's as well. This is who I will use no questions asked.
As far as a convertor I am going use continental when I get to that point. As my final engine combo wont be completed till next year i might just throw a b&m holeshot ( or somthing like this) in it for this season. Let me know if you need a hand. |
Thanks guys, I'll check into all your suggestions.
![]() Quote:
Chris Hunt |
