Old 05-30-2002, 02:44 AM
Trent7276 Trent7276 is offline
I was installing my new water pump and the bolt on the center bottom just kept turning and turning, never getting tight...what can I do if it is stripped? I believe it goes into the timing cover...please don't tell me a new cover!! I replaced this whole thing because the plates and dividers were corroded, and a slight leak from the gasket on the bottom...
Well I sealed up all the bolts with a new gasket anyway. We will see how it holds water tomorrow! Any ideas??
Trent
1968 Firebird 400 Coupe
Muncie M-22 "Rockcrusher"
Trent
Old 05-30-2002, 05:30 AM
Bud Lyons's Avatar
Bud Lyons Bud Lyons is offline
Send a message via MSN to Bud Lyons
Try JB Weld or Devcon. They are epoxy fillers. Remove your water pump and fill the bad hole with epoxy. Let it cure completely. Run a 15/64 drill bit into the epoxy. Then run a 5/16 tap in your new hole. If you let it cure you should have no problems.
WWW.PatriotGuard.org
Standing for those that stood for us.
Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I.
One for your soul; the other for your freedom
Old 05-30-2002, 05:38 AM
Johnp Johnp is offline
Have you thoought about a heli coil, they can be as strong or stronger then new.
John
Old 05-30-2002, 06:19 AM
Bud Lyons's Avatar
Heli Coil will work better.
Old 05-30-2002, 10:54 AM
What is a Heli coil??
Trent
Old 05-30-2002, 10:57 AM
Jim Doran's Avatar
Jim Doran Jim Doran is offline
Trent, their site has good descriptions
http://www.emhart.com/products/helicoil/Default.htm
-Jim Doran-
1965 389 Tripower; 4 speed; convertible
2019 Tesla Model 3 Performance
2016 Chevy SS; Sold
2001 Toyota Tacoma 4x4
2008 Infiniti G35x
