Old 02-21-2003, 08:46 AM
Darrell's Avatar
Darrell Darrell is offline
I am putting i 455 in 69 lemans and was wondering if I can put it in w/ the headers on. I have a motor leveler and was thinking it might be easier to do it with the motor install. Thanks Darrell
ET 12.504
MPH 107
3940 lbs
Darrell's Avatar
ET 12.504
MPH 107
3940 lbs
Old 02-21-2003, 08:53 AM
Half-Inch Stud's Avatar
no.
Old 02-21-2003, 09:11 AM
ascreemer68 ascreemer68 is offline
not only no, but NO.
http://www.stefanjames.com/goat.htm
Old 02-21-2003, 09:53 AM
BASHEIII BASHEIII is offline
Is that anything like.....Hewll no!
Old 02-21-2003, 10:09 AM
Darrell's Avatar
Thanks guys, "hell no" makes it real clear. Darrell
ET 12.504
MPH 107
3940 lbs
Old 02-22-2003, 01:33 PM
cstevens cstevens is offline
Sure does follow these 7 easy steps.
1- Remove front clip
2- Remove body from frame
3- remove steering components
4- Sawzall frame into two equal halves
5- Install moter/headers onto one half of frame
5- install other half of frame onto motor
6- weld frame back together
7- Install steering componants
Old 02-25-2003, 07:31 PM
Bill Meyer's Avatar
Bill Meyer Bill Meyer is offline
Location: West St Paul MN/Mesa,AZ- depending on weather
I guess I'll have to disagree on this one! I have a '71 GT37 w/455block with round port heads. The ONLY way I can get the drivers side 2" hooker header on- is to put it on first, then tilt and twist the engine so the collector goes into the transmission tunnel first, then twist and lower the engine 'til it's almost in. Then hold up the pass header, while lowering in the rest of the way. Then spend 2/3 hrs trying to get those bolts started. I have done it this way for at least 7 years, and it's the only way it works for me. Bill
GT37 3600lbs...as featured on the cover of Pontiac Enthusiast Jan/Feb 2002 DOT/mufflers-all motor
6.49 @ 108
10.14 @ 133
GT37 3625lbs..Fastest bench seat, column shift, all steel,no power adders car at Norwalk
1.35 w/29.5x10.5x15
6.42 @ 109
10.09 @ 133
Old 02-25-2003, 07:46 PM
Guy Mazza's Avatar
Guy Mazza Guy Mazza is offline
Ditto to what Bill Meyer said. With my 69 GTO, I run Hooker Super Comps, and I have to install engine, with the headers "in place" in the eng compartment. Before motor is "in", I have to start installing headers. RT header MUST be installed while eng is just hovering over motor mnts...a real PITA!
Old 02-25-2003, 08:00 PM
Brian Baker's Avatar
I have 1-7/8" Hedman Hustlers with 3.5" collectors (for d-ports) in my 79 T/A and they require an adapter plate between the header flange and the cylinder head.
I'm never buying another Pontiac header that doesn't require this adapter.
I can set the engine on its mounts and slip the headers in from underneath AND be able to get to ALL of the bolts with a socket or wrench. With the enlisted help of a friend, we had both headers on the car and snugged down tight in about 20 minutes (not kidding).
I've never been able to do that with any other header.
Old 02-25-2003, 08:39 PM
While I've never tried it on a 2nd gen. T/A; looking at mine w/ the entire front-end off, I believe my 428 w/ Doug's 1 7/8 x 3 1/2 headers will slide in. I'll let y'all know very soon, as I'll try it. Soon as the cage is finished.
SECOND AMENDMENT: AMERICA'S ORIGINAL HOMELAND SECURITY.
I Misus Rash'!
