Old 07-11-2000, 03:23 AM
vidguy's Avatar
vidguy vidguy is offline
Is the upper control arm shaft kit listed in the catalog for a 64-66 GTO the right kit for a 67 GTO? In other catalogs I have seen the listing for the 64-72 as the same part number.
Thanks James
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
vidguy's Avatar
Thanks James
James
Work
Details here:
Old 07-11-2000, 06:55 PM
Blackcat's Avatar
Blackcat Blackcat is offline
Bonker's-T-Cat Moderator
The upper control arms are nearly all the same. With the exception of the early having a bolt holding the bushing in place. The later ones have a large nut holding it in place. The shafts should have the bolt/nut included in the kit. If you are just replacing the bushings. Just re-use the bolt/ nut on the shaft.
Try calling CRUSHPROOF! 512-386-9889
