Old 06-10-2002, 11:08 AM
A.W.Dille A.W.Dille is offline
I'm experiencing a backfeed problem on my street/strip 71 GTO. Whenever I use my turn signals the needle on my tach starts jumping (an Autometer 3904 w/ shiftlite). The only change I have made to the electrcal system is installing an H.E.I. distributor. Where do I begin to look?
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear
85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book.
87 F350 6.9 4 speed dually
A poor man has poor ways.
Old 06-10-2002, 12:20 PM
george kujanski's Avatar
Most likely the problem is a weak battery connection to the instrument panel area. The xtra current used by the HEI in your ignition circuit plus the current drawn by your directionals is causing a voltage drop in your battery feed harness. As a result your tach does not get enough voltage to work correctly.
Look for a bad/weak fusible link or a corroded fuse boxignition switch terminal.
Regards, George
