Was that vague enough??!! Got a 64 Safari recently that ran like a champ but leaked like crazy so I pulled the timing chain cover off to do the t-chain, gaskets, water pump, etc. The inside of the cover was absolutely crusted with petrified oil! This car very well could have it's original oil it's so crusty. Looking down over the front lip of the oil pan shows a lot more of the same in the pan. Basically hardened, oily crud.
My question is this: Is there any way to treat/remedy this without dropping the pan? I'm obviously concerned about the oil pump pick-up screen getting clogged with debris and killing the motor. The motor was clearly maintained VERY poorly but dang it ran strong! I'd like to avoid tearing it down any further. Thanks in advance for the suggestions & tips fellas! John |
Buy the motor flush available that requires you to crank and run the engine without driving it. Then do a couple of changes with good oil and some Rislone. You'll either be good to go or rebuilding it.
http://kurtspontiac.homestead.com/DavidJones69GTO.html
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core.
use the flush and marvel mystery oil.
Received my first solution in under three minutes and had two solutions in under 25 minutes! Man, what a resource we have here! Can't thank you enough!
Ummm, just from personal experience, if you have that much crud, leave it or overhaul. Using any kind of flush, you run the risk of loosened crud clogging oil passages or the pump pick-up screen. Don't do it.
