Does anybody have or know where to get the proper bolt hole locations on the trunk to mount the rear spoiler on a 69 T/A ???
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s |
Gm drawing # 9797079 states that the dimensions are 15.4 inches from the center line of the trunk lid to the stud holes. The stud holes should be .312" diameter. The stud spacing (between the studs on one side) is 3.63 inches and the dimension from the from the rear edge of the trunk lid to the first stud is 3.9" When I installed mine I laid out the trunk lid so that it was exactly where I wanted it then modified the hole placement so that the wing sat perfectly between the rear quarters (same gap on both sides).
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int 1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int 1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int |
Thanks for the info/reply. I'm sure this willbe very helpful.
