I removed my aftermarket chrome valve covers from the 455 and the stock covers seem to be a bit short. Even though no oil drippers are installed on the factory covers, the roller rockers are hitting the lower edge of the covers slightly.
Two questions: Since this is an AC car, the air conditioning to intake braket is pretty close to the passenger side valve cover. Does anyone make a thicker gasket that will cure this problem? If not, any recommendations on tall covers that look a bit stock? If I use tall covers, I'll cut the AC bracket and modify it to fit. I'd rather use stock height valve covers, but the tick is driving me nuts. Dave |
Use 2 valvecover gaskets per valvecover.
or Spotty has the extra thick gaskets for this situation.
95 Towncar that needs more TQ. Sold 2023: 12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
If I use two gaskets, should I use some RTV between the two or will they seal up without?
Dave |
Dave
Use Felpro part # 1627 - thick cork gaskets, had to use them to clear my roller rockers. Barry
66 Corvair Corsa - not so stock 74 Formula 400/4 sp - stock 79 TATA - almost stock 78 TA - owned it since new - not so stock (11.28 at 118.6) |
Same here. I ordered mine from Nunzi which were $26/pr. No more clearance problems. You may find you need a bit longer bolt for the valve covers.
Not sure how much clearence you need but, the Felpro #FPP-1627 is 1/4" thick as stated above and they are only @ $18.00 in Summit and Jegs!
