Old 06-09-2005, 02:17 PM
DADZZ64's Avatar
DADZZ64 DADZZ64 is offline
hey got a chance to score on to a set of 670 heads and from the info i got they are from a 1967 400 std HO Valves 2.11/1.77 72 CC or CR Screw in studs- dual valve springs- D port my question is would these heads work better then the 4x1H heads that are on my 1974 455
DADZZ64's Avatar
Old 06-09-2005, 08:38 PM
gtoguys gtoguys is offline
Yes they will work better if you can find 110 octane fuel. Your compression ratio will be somewhere in the neighborhood 12:1 or 13:1
Old 06-10-2005, 06:18 PM
bonneville Joe's Avatar
bonneville Joe bonneville Joe is offline
What he said. The compression will be way too high for street use. Got a set of 7K3s that would work much better.....
_____________________________
www.classicpontiacrescue.com
