Old 05-27-2002, 03:14 PM
PHILLYGOAT PHILLYGOAT is offline
Many of you have followed the saga of my 490. In a nutshell 3yrs,8runs,4dyno runs have cost $$$$$$ from original build,2 rebuilds including welding and hard chroming the crank and now it sits with a 6" x 6" hole in the block.
However, as I look at the crank through that hole it looks like it might just need to be turned to be OK. Then all I would need is some nice rods(with 7/16" Bolts!), one new piston/ring set, bearings and a new 400block.So, am I outa my mind for even considering using the crank again?? I feel it is mocking me, but I am not sure if it's because of not making it work or thinking I should try one more time.
HEEEELLLLPPPPPP ME!!!!!!
Phil
http://ourworld.cs.com/GOAT490/myhomepage/auto.html
It looks GOOD, runs FAST, just SMOKES so much it is EMBARRASSING to drive!!!
Phil
Old 05-27-2002, 03:20 PM
Goatman Goatman is offline
On Vacation
ONLY because I just sold my 3.875" billet crank, you should try re-using yours.
If, of course, it cleans up nice.
Old 05-27-2002, 06:11 PM
Tim Swain Tim Swain is offline
We thruogh a rod in our race car, last weekend at Englishtown. Went strait through the oilpan. Our crew chief was gonna re-use the crank if at all possible.
Old 05-28-2002, 02:07 PM
Half-Inch Stud's Avatar
...skip the hard-chrome this time.
H.I. Stud
Old 05-28-2002, 06:35 PM
PROBRD PROBRD is offline
I would have it magnafluxed to make sure there are no cracks and if it can be turned go for it.
1/8th mile 6.52 @ 104
1/4 mile 10.43 @ 128
