Old 06-03-2002, 01:04 PM
HANDSEL HANDSEL is offline
Is it really necessary to put two sending units for water temp in a 72 Lemans with rally gauges? I got a hand writen wiring diagram that states that I need two sending units for water temp. Is this right?
Old 06-03-2002, 01:24 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
One of the senders is for the gauge, the other is for the TCS system. I'll need to check out my old info but I believe it was there to advance the ignition timing when the coolant reached a certain temperature (near overheat) to help cool the engine down.
Hope this helps,
Lloyd
Regards,
"455HO" Lloyd
Old 06-03-2002, 03:11 PM
It isn't a stock Lemans It now has a non-vacuum advance dist. I now have a MSD Ignition. By not putting this sender in would it effect the gauges function? I just wanted to put the rally gauges in my car. Pretty much everything on the engine in aftermarket (intake, carb, ignition system exhaust etc). The only vaccum line I have is for the trans modulator!
Old 06-03-2002, 03:33 PM
Lloyd-TX's Avatar
You don't need the additional sending unit - just install the one sender for the gauge.
Later,
Lloyd
Regards,
"455HO" Lloyd
Old 06-04-2002, 07:05 AM
Cool! Thanks alot
