Old 03-05-2005, 09:50 AM
87Olds442 87Olds442 is offline
I got a 403 I'm Looking to build. I know that replaceing the Heads too up compression is a way to go. I Think I want to go with this piston here http://www.kb-silvolite.com/performa...tails&P_id=354 This will bump my compression a couple points. My question Is should I use the Factory 4A heads and mildly port them or Use a set of 455 heads. I got a set Of G head from a 455. This will be a street motor and I got a 2004r with 2500 stall. running 3.73 gears.
Old 03-05-2005, 09:13 PM
68post 68post is offline
http://www.realoldspower.com/phpBB2/...r=asc&start=15
Look at this build-up, it's what I would go by and should answer alot of your questions. The young guy that wrote this is a partner with his father in a popular Speed shop/engine builders , and Oldsmobile specialist.(FCR Performance in Omaha,NE.)
Tim King
Old 04-21-2005, 07:45 AM
Lee's Avatar
Lee Lee is offline
I can get a set of early 350 heads, if you are interested. They have been mildly ported, chambers polished, center exhaust dividers welded flush to gasket surface, and head bolt holes enlarged for 403 bolts.
Anyone interested, contact me at:
[email protected]
Lee Atkinson
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 04-27-2005, 01:10 AM
bmpmdf bmpmdf is offline
You need to email this guy, Bill Trovato at; [email protected] He built a very nice 403 combo for the engine masters contest.
Have A Great Day
Old 11-30-2005, 10:01 PM
js machine js machine is offline
Default Diesel Block
Bill Trovato used a 350 OLDS DIESEL BLOCK to achieve 409 cu in.A TRUE 403 is one that is used in the 77-79 GM-T/A's etc..
Dick Miller Racing built a TRUE 403 block (yes windowed mains) using one of my J&S Machine halo girdles. HE FINISHED the EMC contest with engine intact!! FCR and the Bandit didn't NOT even SHOW for the event ( and having a 1000. + girdle attached) HERES the #'s of DMR 403!!
http://www.dickmillerracing.com/PHR_403.htm
www.jsmachineoldsmobile.com
