Old 12-30-2002, 06:33 PM
70 pree 70 pree is offline
I would like to install a stock h.e.i distributor in a 70 g.p. 350 horse 10:5 to 1. what would be the right choice for a spark plug and gap? should i use the plug called for on this car or use one used on later 70's model with a bigger gap?
Old 12-30-2002, 08:44 PM
Txbobcat Txbobcat is offline
I think if you still have the big plug heads you would be pretty well limited to changing plugs from the originals.
Old 03-16-2003, 06:37 AM
Sun Tuned Sun Tuned is offline
Going out on a limb without actually looking, but I think a R45S. Anyway a colder plug than what is supposed to be there originally is not necessarily needed. Many will automatically change heat range just cause they heard that was the thing to do, not always what needs to be done. Try the stock heat range first, but you will need to change the original gap setting from .030 to .045 for the HEI, to get the full benifit from it.
Old 03-19-2003, 08:11 PM
grandville455's Avatar
grandville455 grandville455 is offline
Sun Tuned I have tried to email you but get no response am i using the wrong email? ([email protected])
Grandville455
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 03-19-2003, 10:21 PM
That's the right address, I don't know why it won't work. I've e-mailed you 2X with no response either. Maybe your 'puter and my 'puter don't wanna 'pute. I know how to fix it though.....901-458-3287. Let your fingers do the walking....it's a snap!
Old 03-20-2003, 05:17 AM
Thanks be talking today!!!!!!!!
Grandville455
Darby
