Old 05-01-2002, 07:30 PM
jfmcconnell jfmcconnell is offline
I want to build up the original 389 in a 64 Catalina, does anyone know of a good book to use for guidelines/part suppliers, etc. I want to keep it pretty close to stock, but I'd like to get 350HP. I think I'd like to put a tripower setup in it to...any advice is appreciated. Thanks
Old 05-01-2002, 10:02 PM
Tom Vaught's Avatar
Boost Engineer
My suggestion would be to copy the highest HP
389 engine: (the 1966 GTO) and use the same cam,
lifters, etc. The tri-power for a 64 GTO or big
car would be correct but any 62 to 64 tri-power
would directly interchange. I know the manifold goes back to 61, guys but it has been a LONG time
since I saw a 61 tri-power. If you are going to drive the car you have two choices. Retain the high compression motor specs, etc and buy good but
expensive gas for occasional drives or put in lower compression pistons and run the panther pi$$ that is out there in quantity. A set of the "Long Branch" exhaust manifolds would help the car breathe but are not totally necessary. Tom V.
Old 05-01-2002, 10:33 PM
..thanks, do you know where I can get the part numbers,specs etc. for the 66 GTO, without paying too much for stuff I don't need?
Old 05-01-2002, 10:55 PM
Engine-Ear's Avatar
I am selling a rebuilt '66 YS (GTO) 389...
go to GTO parts for sale for a little more info.
email me if you're interested in more details/
RediRad circuit designs, branding and intellectual property are for sale.
Serious inquiries only.
Old 05-01-2002, 11:38 PM
what is "1-RPO"? looking at engine combinations for 64 big pontiacs, there is a 350HP 389. it says Cam#524009, high output fuel pump, special lifter assembly, 11110 52 dist., and 10.75:1 CR. I think this was an option for Catalina's too...? where can I find more info(heads?, valves?)...and how many HP was/is the 66 GTO's 389?...and how much is "good expensive gas"?..Thanks
[ May 02, 2002, 12:01 AM: Message edited by: jfmcconnell ]
