Old 02-23-2001, 02:15 PM
slowbird's Avatar
slowbird slowbird is offline
What is the best way to put an fittings on the hoses and is the best way to cut the hoses without getting the steel wire to fray.
slowbird's Avatar
Old 02-23-2001, 03:19 PM
Tim Corcoran's Avatar
There may be better ways to to it but I will share what has worked for me. When cutting the steel braded hose I tightly wrap the area to be cut with masking tape, several layers. I then place the hose in a vise keeping the area of the cut as close as possible to the vise jaw. I then cut with a very fine tooth hack saw. The tapes does not completely eliminate fraying but does keep fraying to a minimum. I then use a bit of WD-40 on the fittings to prevent galling and it helps the fitting in the hose also. I don't like the red/blue an fittings as they scratch and show signs of wear very quickly. I like the nickel plated aluminum fittings that look like stainless but without the additional cost and weight. There is a special machine for cutting the hose but it's not cost effective to go out and buy one. Just my .02.
Tim Corcoran
65 LeMans 11.13@120
going into the 10's
this winter
Tim Corcoran
Old 02-23-2001, 05:06 PM
slowbird's Avatar
What about using an air cut off wheel to cut the hose, would this be better than a hacksaw.
Old 02-23-2001, 07:06 PM
Rashionality Rashionality is offline
I have always used black electrical tape around the end of the hose and not masking tape. The routine in the vise is the same but I prefer to use an air grinder or Dremel to cut the hose as this is MUCH easier on the arm and tends to fray less than with a hacksaw. Just remember to mark the hose when you slip it in the fitting to check if when you tighten the fitting the hose does not pull out of the end. I always used a pencil and traced around the end of the fitting after the hose has bottomed out in the end.
Hope this helps.
"Take your time, don't live too fast, troubles will come and they will pass...
Old 02-23-2001, 08:56 PM
TinInjun's Avatar
TinInjun TinInjun is offline
Location: American by birth, Southerner by the grace of God
Slowbird:
See if the picture below helps you. If you have any other questions with this, shoot me an email.
"Run wild with an Indian, not with the crowd in a Chevy"
Check out my restoration at http://members.aol.com/jetmech15/gto
Less said,,,,,,,, Less mended.
Old 02-23-2001, 10:21 PM
Bigred455 Bigred455 is offline
Do you mean put the tape on ONLY we cutting the hose and take it back OFF once it has been cut?
George Hill
'63 Star Chief, '95 Chevy P/U, lots of BMW motorcycles and cars
Old 02-23-2001, 11:43 PM
Bill Bolin's Avatar
Bill Bolin Bill Bolin is offline
Slowbird, I sell Aeroquip hose where I work. I can send you an Aeroquip catalog with pictures and instructions on how to properly cut, assemble and install steel braided hoses. I prefer using the SS braided hose with teflon inner tube due to higher pressure, higher temperature and more chemical resistance capabilities. This is the same hose used for nitrous or brakes. It holds up much better than the rubber lined hose for trans lines or if you use alchohol for fuel. For regular fuel or oil either is fine. Send me an E-mail with address so I can get the catalog out to you.
Old 02-24-2001, 06:58 AM
Craig Berkheimer Craig Berkheimer is offline
The cutoff tool, I find, to work much better than anything.
Outlaw Pontiac Racers Association
"For Those Who Live The Legend"
www.outlawpontiacs.com
Old 02-24-2001, 08:57 PM
71Sport 71Sport is offline
I have found Russel fittings fit much better than Areoquip. I have had nothing but trouble with the Areoquip fittings with their hose (smaller ID.)
The electrical tape works great.
DON'T use WD-40 on rubber parts, it will attack and degrade them.
[This message has been edited by 71Sport (edited 02-24-2001).]
Old 02-25-2001, 12:13 AM
71 Sport,
What do you use as a lubricant, and don't say KY gel.
Tim Corcoran
65 LeMans 11.13@120
going into the 10's
this winter
Tim Corcoran
Old 02-25-2001, 09:53 AM
Guy Mazza's Avatar
Guy Mazza Guy Mazza is offline
Use tightly wrapped tape (I use duct tape) use a fresh cut-off wheel on a die grinder & cut through the tape at desired length, unwrap tape. A little oil can be used as a lube. Be sure to flush hose out w/some carb cleaner & compressed air before use.
Old 02-25-2001, 12:36 PM
slowbird's Avatar
Ok what are the size of the hose then. I thought that a #10 was equal to a 1/2 line but the book say that #8 is 1/2. I thought #8 was for 3/8 line.
Old 02-25-2001, 12:48 PM
RPM's Avatar
RPM RPM is offline
Send a message via Skype™ to RPM
Each number is basically 1/16". So -8 would be 1/2".
Old 02-25-2001, 08:14 PM
66Bronz 66Bronz is offline
After lots of experience working with the stuff on motorcycle brake & fuel lines, I can say, 1) duct tape is better than blacktape for keeping the wire down when cutting <black is punctured easier> and 2) with a really STOUT pair of scissors, you can <slightly> bevel the end of the hose for a smoother entry, after lightly lubricating with oil. Take the tape off 1st.
Old 02-25-2001, 11:18 PM
divide which ever number you have by 16; 6/16=3/8, 8/16=1/2, 10/16=5/8
George Hill
Old 02-26-2001, 08:46 PM
Herb Hagan's Avatar
Herb Hagan Herb Hagan is offline
Just a side note, all AN (Army-Navy standard)
hose/tube fittings are 37 degree flare angle and should not be used w/SAE automotive hose/tube fittings, they are 45 degree flare angle. It is also not recommended to use one manufacturers hose with another manufacturers fittings, I have personally experienced failures due to this scenerio.
Good Luck,
Herb
74 Ventura 462/#13 heads/3350#
10.38 @ 128.89 MPH, N/A, Stock suspension, 275/60 Radial, Street legal, Tagged & Insured
Old 03-03-2001, 09:28 PM
slowbird's Avatar
I just wanted to thank everyone that gave me advice. I really helped and the whole process was easy, would have been a little easier if I had a vice.
THANKS
Old 03-04-2001, 11:17 AM
Triggerman Triggerman is offline
Slow, I'm sure you have some vices...you just haven't looked hard enough. Ask your wife. She will know. TM
Old 07-29-2007, 03:16 PM
sandmanjoe's Avatar
sandmanjoe sandmanjoe is offline
can AN fittings be reused? or once you assemble it thats it...
